Amana ACS3350AS0 - Disassembly help needed
JPNY
New York
ACS3350AS0
Amana
I'm trying to figure out how to get to the control board area and the ignitor area on my Amana ACS3350AS0 range.
The range is calked in so I can't really pull it out (unless really necessary). The few screws that are exposed dont appear to fasten the two areas I am trying to access. Can't find a online service manual that shows how to access these two areas.
Sure it is really simple if you know the "trick".
I couldn't locate the service manual for your model, but the spark module looks to be under the main top, when you click the part link to the spark module below, you will see a video that gives you the general idea of how to access it.
Spark Module WP31962701
The clock oven control board you have to access from the back, so you will need to pull the range out from the wall for that.
The clock oven control board is #4 here:
Buts Its No Longer Available.
