Amana microwave vent fan won't turn off
dolby2thx
california
mvh350ss
-major brand-
hello
I have a Amana microwave mvh350ss with the exhaust fan that sucks the air from the stove to the outside of the house. Yesterday after cooking food on the stove for awhile with the microwave fan turned to the high position, the fan will not turn off. I push the vent fan switch to off and the display says off, but the fan continues to stay on. The only way to turn it off is to unplug it. Once i replug it in the fan functions fine, turns off when pushed. The problem happened today again. Had to uplug and everything was fine. I read somewhere it could be the thermostat? Any suggestions or info greatly appreciated.:)
I found...
MVH350SS-P1323209M
MVH350SS-P1323209SS
MVH350SS-P1323222M
Normally the bottom of the microwave ( inside ) is protected by having a thermostat that will close and turn on the exhaust fan if the oven bottom gets too hot. Stuck/sticky thermostat, stuck/sticky relay on the board, pinched wire, shorted fan motor would be possible trouble makers....probably from most to least common.
