Amana NFW7300WW00 Tandem Washer not starting cycle
Jcron
Florida
NFW7300WW00
Amana
Washer was mid cycle and started beeping. Will turn on but won't start new cycle, and eventually flashes 6-1 on wash light.
Hi, Usually error code F6E1 is the MCU that is bad.
F6E1--->SERIAL COMMUNICATION ERROR--->The communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes/Procedure
- Unplug washer or disconnect power.
- Check that the power cord terminals are connected at the right position to the RFI filter (white-Neutral/ black-Line).
- Check that the two ground switches are pressed correctly by the toe and rear panels.
- Check that ground switches are fitted correctly, and are not broken and the green ground wires are connected correctly.
- Make sure that both ground switches are not broken or scratched.
- Make sure that all the ground harnesses (green wires) are connected correctly, and are not broken or with wires detached.
- Make sure that all wire harness connections from the CCU (MI3 cavity), main Motor, and MCU are not broken or with wires detached, and that connector internal pins are visible.
- Check for continuity from the MCU connector wires to CCU (MI3 cavity) connector.
- If the continuity diagnosis failed, the Main Harness must be replaced.
- Make sure that all the connectors are fully seated.
- Check the drive system for any worn or failed components.
- Plug in washer or reconnect power.
- Verify the washer operation by running the Diagnostic Test cycle. See page 5.
- After the diagnostic test has finished, unplug washer or disconnect power and wait for 15 seconds.
---->FIRST--->You may want to UNPLUG THE MACHINE FIRST, then remove the MCU(Motor Control Unit) and look at the circuit board closely and see if you notice any burnt spots on it, IF SO, then order the new MCU below and that will fix it.
Here's the MCU for this model:
Main Control Board WPW10384843
