FIXED Amana NTW4700YQ1 Not Spinning?
JDWhit
United States
NTW4700YQ1
Amana
Clothes are coming out of the washer wet and nothing seems to happen during the spin cycle. What may be the problem? and how/where can I look to diagnose? MANY thanks in advance!
JDWhit
United States
Turned it over and found this?
turned it over and found this, bother the spindles work freely it appears..
Good Photo, I see what happened.
Here's the part you'll need to fix it(Video Included in part link):
W10721967 Splutch Cam Kit
Wait,
I just found your thread from Dec. 2015 where you replaced this same part before: FIXED: Amana NTW4700YQ1 intermittant noise
You must keep that machine running non-stop.:)
Or your overloading it, overloading the washer will cause this part to break every 1 1/2 as well.:)
JDWhit
United States
Thank you for the response, although I am still a bit confused. The nut and pulley have fallen off and worn out a hole in the belt shield. However, looking at the splutch cam assembly, it all looks completely intact? what am i missing here?
also, should I get a new belt? and belt shield? if you can send me the parts link
JDWhit
United States
Belt & Belt shield
Wonderful information again, thank you!
Check out this pic, I guess the pulley wore a perfect hole in the belt shield
Do i need a new belt shield? and should I get. belt? it's looks like a bit of it
scrubbed of on the shield, although the belt itself looks good and intact
THANK!
Glad to help.:)
Thanks for the donation!
