Amana Refrigerator ASI2175GRS01 Ice Maker Stopped Working
nschmitz
Kansas
ASI2175GRS01
Amana
I have an Amana fridge that ice maker stopped working. At first, the ice tray was freezing in a single block. After defrosting, it would cycle a few times and then freeze again. Freezer is a good temp and water filter is new. Now, water is not even reaching the ice maker. Water dispenses out of fridge fine. Could this be an inlet valve issue? At first, I thought it was, but now that no water is reaching at all I am not sure what part to replace/how to fix. Any thoughts?
I think you nailed it:
nschmitz
Kansas
I replaced the inlet valve. Still no water being sent up to the ice maker. Should I be looking into a replacement ice maker or could there be something else to try?
You can force cycle the ice maker and check the voltage at the valve. If it's not the valve it must be the ice maker:
