AMANA SXD522VE PROBLEM
BAUMA-TS
greece
SXD522VE
Amana
Good evening I am new in the forum.
I have a AMANA SXD522 VE side by side .
Some days ago a technician changed the compressor because it was off and needed to be changed.
There was a control of the fridge in all parts and it was ok. The fridge functions good but the freezer
is going up to -16o C and the compressor doesn't stop ( because it can't reach the appropriate temperature).
The technicial put the freon R-134a, but before that, he didn't measure the volume of the freon that he puts ,without the right pressure.
He imported it by expirience. The label directions for the specific model for freon are exactly .0149kg. (What that means? 149gr?)
allowable pressure 26/9bar. (What that means? 2.8bar?). He fix it without take in mind the label directions.
Do you believe that this is the problem for the freezer temperature?
thank you
Hi, as much as we would love to help you, we can't, your European model is completely different than the USA models.
Try a European forum called UK Whitegoods.
