Amana washer- Model-NTW4605EW0. Stops at final rinse
Sherrya
NTW4605EW0
Amana
Stops at final rinse, then I either have select the rinse/spin or start it all over.
When it stops at final rinse it does not fill with COLD rinse water? Or it fills with COLD rinse water but does nothing else? No sounds or anything like its trying to do something?
I'm attaching your tech data sheet below. Get into the ACTIVATING THE SERVICE DIAGNOSTIC TEST MODES and see what fault code you get.
On Page 2 of your tech. data sheet do: ACTIVATING THE SERVICE DIAGNOSTIC TEST MODES
Then do FAULT CODE DISPLAY MODE on Page 3
Then you can see what fault code/codes you are getting on Page 6 and Page 7: FAULT/ERROR CODES
  • Tech Sheet - W10740573 - Rev B.pdf
What FAULT CODE did you get?
Unplug the machine from the wall outlet for about 5 minutes, then plug it back in and see if the door unlocks.
