DippyFresh
- NTW4516FW3
- Amana
- 1-5 years
Washer will sometimes just not rinse when it gets to the rinse part, of course that holds up the whole cycle. Sometimes it will also stop during the fill.
I can hear the pump draining the water during the drain portion of the cycle so that part is fine.
Agitator is fine.
It spins fine (tough there is a bit of a delay before the spin actually starts).
Here are some videos showing what I mean when I say water just keeps stopping on its own.
At a loss on this one, solenoid on the cold inlet could be bad maybe? I'm gonna try turning it to hot water and starting a cycle to see if it's both solenoids that are bad or just the cold water one. It won't stop shutting the valve after a few seconds as shown in the video. So thought maybe it could be the autofill sensor thinking its full an stopping early? I had the washer full of water and the tube was still empty coming up from the back to the control board. Might need to open the main back part and disconnect the tube from both ends and blow it out.
Thoughts?
Agitator is fine.
Thoughts?
