Amana water inlet valve by Invensys replacement
rcabrale
Brea, CA
I have an old Amana BTM (8-10 yrs) Refrig freezer, cabinet depth unit.
My ice maker inlet tube is freezing up so the water is spraying out of the ice maker system. I believe, based on research on this forum, I have a slow leak that is freezing in the tube and not allowing water to follow properly into the ice maker. Easy fix right... problem is I dont know the model number (sticker was removed long ago). I inspected the inlet valve and posted the photos of the part i need. I just cant figure out the replacement part.
Amana water inlet valve by Invensys number 12544105 MEXICO 099C02
What is the correct replacement part?
