ARB8057CB Amana Refrigerator is now having issues; not cooling
rcabrale
Brea, CA
ARB8057CB
Amana
Back in early 2020:
NEW issue. Recall I had issues with the freezer back icing up, so I replaced the thermostat timer and seal ... problem solved. Now my refrigerator section is cool kinda (about 43-45F) but condensation, ice is building up at the back vent. I cleared away any blocking but once a month or so, it starts to ice up (see image) and heat up. NOTE: I checked seals and there are no major gaps or tears. The fan in the freezer is spinning bc I can see it.... No ice buildup in the freezer... any thoughts?
Make sure the condensor coils are clean. Leave the machine plugged in and running. Remove the evaporator cover and take a picture of the frost pattern on the evaporator coils and post it here. Be sure to replace the cover when done.
Thanks Rick, ill do that tomorrow morning. What will the pattern on the freezer evaporator coils tell us? I'm just curious to know.
If you have a sealed system problem or defrost problem. I suspect you have a sealed system problem.
Here you are, I hope this doesn't show a sealed system bc that will be expensive.
I checked the heater, while taking images, bc i manually activated the timer to start.... it gets hot so can we assume it's good?... If yes, I will replace the timer and thermostat to be sure. Do you think that will fix things?
Also, to confirm we have no seal issues?
Yes, The thermostat is good. Just replace the timer.
