Asko W6022 fails to load water and exits
laguna_b
os Gatos, Ca.
W6022
Asko
The water solenoid does not activate and machine times out. There might be a buzz as well.
laguna_b
os Gatos, Ca.
This does not seem to be the problem as the trap was cleared of coins and the machine seems to drain successfully. Next step?
That's all I know, I have no clue other than that. I know nothing about these Asko models except for the drain pump basics of cleaning it out.
Hopefully another tech. or member can shed some light on this for you, that knows this Asko brand well.
Jbest
Reservation
It's possible your water solenoid is bad. I would take the top lid off and check the solenoid terminals for continuity. If that checks, then I would test the wiring connections at the water solenoid for voltage (assuming your are comfortable testing the high voltage). I believe there s/be 240v. See if you are getting power to the solenoid as soon as you start the cycle, and if not, consider replacing that solenoid.
laguna_b
os Gatos, Ca.
Thats exactly what my next steps were going to be. I was thinking though of after that.Since opening it up as a stacked system is a bt of a pain. But when my tenant gets back I will try this with his help....Thanks
