rottenjeff
- DV56H9100EG/A2
- Samsung
- 6-10 years
I have a DV56H9100EG/A2 (6-8 yrs old) that stopped heating. I found that the heating element was bad so I replaced it and all of the sensors (high limit, thermal fuse, thermistor and the motor cut-off fuse). It got nice and hot, but apparently too hot and blew the thermal fuse. I cleaned all the ducts (they were fine), found no short in the heating element, replaced the thermal fuse and put the old high-limit back in. Same thing - heat and then no heat - thermal fuse blown. So using two high-limits, I blew 2 thermal fuses. I bypassed the thermal fuse and ran it and was able to watch the high limit cycle on and off - turning the element on and off. (Is it possible that I have 2 bad high-limits that are both opening too late?) So the control board seemed to be the next option. I replaced it and it blew the thermal once again. Reading through some of the posts I decided to test the wiring. The thermistor on the blower housing is at 11K at both the thermistor itself and the connector. The thermistor on the heating duct in the back is at 310K at both the sensor and the connector. The heating element wires (Red and White) are good to the control board connectors and the heating element blue wire is good to the connector at the motor.
I've got 2 sets of sensors arriving tomorrow, but I'm not too optimistic. The only thing I haven't replaced that might make sense is the heating duct thermistor at the back of the dryer. I'm not sure what its room temp reading should be but mine was at 310K.
This one is really throwing me for a loop. Any ideas?
