ATF6000FS1 Frigidaire affinity washer pause mid cycle with water in the tank
Danick
Gatineau
ATF6000FS1
Frigidaire
Hey,
My frigidaire affinity stop mid cycle. When I try to start it again, i just get the pause message. Also, the tank is half full of water.
I try to clean the filter and pump. I thought its might be ok, but when I tried again, it pause mid cycle. Also, my error code is E41
Corrected model number
ASF6000FS1 does not pull up as good, ATF6000FS1 pulls up as good, please recheck you model number.
Is the tub still full of water? If so, put the machine in drain/spin and see how fast the water comes out the drain hose.
Drain Pump 137221600
E41=Control board thinks the door switch is open--->Refer to test (6).
Test 6:
1. Is the loading door closed? No. Close the door. Yes. Go the step (2).
2. In the J2 plug on the control board, measure voltage from the black wire to ground with power on.
0 volts. Check the door strike. If good, replace the door switch assembly.
120 volts. Replace the control board.
Here's the door latch/lock assembly for your model you can order if needed:
Door or Lid Latch Assembly 131763256
There is a video to access/replace it in the door latch/lock assembly part link.
Main Control Board 137006030
