ATF6700FS2 Frigidaire washer won't fill or drain
salicorre
PR
ATF6700FS2
Frigidaire
I have a front load Frigidaire/Affinity washer. If I try any washing cycle, it will fill water for a couple of seconds and the stop. After a while it will fill again for a couple of seconds and then stop. If I try the spin cycle it will begin draining and then stop(similar to the fill symptom). I replaced the water level switch and tried a new main board-no change. Door lock and inlet solenoids seem to be ok. Any suggestion will be greatly appreciated.
