AWN412 All the cycles stop at rinse
jerryp
co
AWN412
Speed Queen
I have a Speed Queen AWN412 washer. When the timer gets to the rinse cycle it just stops. This happens with all 4 of the cycles. Runs fine up to that point. Right before the rinse step the washer drains normally. Then when ready to fill for the rinse nothing happens.
I thought maybe it was the timer but this happens on all the cycles.
Then I thought maybe the cold water value, but I can run initial fill with cold/cold setting just fine.
Any thoughts to what the issue is?
Hi Jerry,
Take the electrical connector off the cold water solenoid and put your meter probes in it and see if your meter reads 120 volts where your timer stops at rinse.
If no 120 volts, then your timer is the culprit.
Here's the timer for your model you can order:
SpeedQueen 38881P TIMER
If 120 volts is present, then your water inlet valve is the culprit.
Here's the water inlet valve for your model you can order:
201468P Valve,mixing E-1
