AWN432SP113TW04 Speed Queen Washer - Dripping water into tub 24/7
mjbr24
USA
AWN432SP113TW04
Speed Queen
My SQ washer is dripping water into the tub 24/7. I've researched and assume it's the fill valve/water inlet valve, but I'm having trouble finding the part #. Also, anyone have any good videos on how to replace? I see videos showing Maytag replacement from the control panel, but my SQ has the valve on the back with its own access panel.
Thanks in advance to people doing great work on this forum!
Most likely, yes. If there are any sediment screens in the ends of the water hoses, those being partially plugged might cause it was well.
Your washer could have used one of two different valves depending on its serial number.
LINK > AWN432SP113TW04 Water Fill Valve
After serial # 1810000001 use:
LINK > Water Fill Valve after serial 1810000001
(no photo).
I do not know what the difference is but different mounting and flow rate changes are likely.
I could not find any videos about replacing the valve on that brand. I did locate a service manual for that model that hopefully describes the process.
LINK > SQ Washer Service Manual 201520R6 PDF
Using the links provided in forum messages to trusted parts vendors helps support this forum and the professionals that give their time to assist you for free. Please give back by utilizing the links provided in replies.
I did find this video about a slightly different SQ washer model. It might give you some ideas for yours. The top likely needs to be raised which would probably require the front panel to be taken off as well.
mjbr24
USA
Thanks for the part no. I have ordered the correct one based on my serial number. i'll give this a try tomorrow when the parts arrive. Appreciate the help.
