FIXED AWN542 Speed Queen Washer Noise
CraigNC
Coats, NC
AWN542
Speed Queen
Any thoughts about what this noise might be? Just started on my Speed Queen AWN542. I'm thinking it's the bottom pulley area. Any thoughts on best approach are appreciated!
Unplug the washer and take the belt off, then plug it back in and start it right there when its making this noise, so we can see if its a motor noise or a idler pulley noise.
If the motor alone turns without that noise, then check your idler pulley to see if that's where the noise is coming from, if so order this kit below.
Here's the belt and Idler pulley kit for your model:
SpeedQueen 959P3 Kit,idler Lever
Glad to help, let us know what you find.
CraigNC
Coats, NC
Took the belt off and noise stopped. I replaced the idler pulley and that fixed the problem. Thanks.
Excellent Craig, glad to hear that. (y)
