Pjtreacy
- BCA5105SG-1
- 6-10 years
Brand is Avanti. Checked beverage center yesterday. It was warm inside. Pulled out the unit from under the counter. Fan was running, compressor was hot to the touch. Unplugged let cool down. Upon looking at the relay, i noticed it looked like the connection between the female wire connector and the male on the relay was charred. The wire insulation near the connector was also brittle and hard.
i removed the wire, then the relay and tested the three posts on the compressor for continuity. there was continuity between each of the posts. The relay for the unit is marked QP2-4.7G. Could it be possible that the relay is bad? A replacement is not very expensive but before i go chasing parts I thought I would reach out here. What makes me think it may be more than the relay is the fact that the compressor was very hot to the touch.
Thank you in advance for any help.
