Blinking lights SHE3ARF6UC/22 won’t start
steve_canyon
Cleves
SHE3ARF6UC
Bosch
Cycle time light flashes 2:10 in sync with Auto wash light. Arrows do not move light. Pressing start does nothing. Holding Start button does not reset. Turning off circuit to dishwasher does not reset. Appreciate your thoughts.
Here
US
DW has to be powered off (unplugged or similar) for at least 5 minutes. Not sure how long you left the circuit off. Is the door closing properly?
steve_canyon
Cleves
Reply to Here
Thanks for responding. Door seems to close properly with normal “click”. The power was off for an hour.
Here
US
Door and duration of unplug were my only two leads. Do you have a tech sheet that describes the diagnostic mode and features?
Here
US
The "Customer Service Program" (diagnostic mode) is really simple to run. The tech sheet has complete instructions. You might find yours in the same place as mine. Remove the bottom metal toe panel (two screws), Feel around on the backside of the plastic molded supports. There was one that was u-shaped. The tech sheet paper was folded up and scrolled up and tucked into that u-channel. It could not be seen from the front. I had to feel around for it.
JOBOGGI
MD
This exact issue occured with my bosch SHE3ARF6UC/22 dishwasher. Is there anything else I can do? I hAVE TO FIND THE SHEET noted ABOVE? Any follow up on the above would be appreciated
