Bosch Axxis+ Washing Machine Pump Block
abamjam
Colorado
I keep getting the error message "Pump Blocked?" after several cycles in my Bosch washing machine. I've followed the directions by adding 5 gallons of water and draining through the front drain, unscrewed and cleaned up the trap up front, and even taken the drain house out to blow some air into it to get the lint out. After I did that the first time, I ran a few complete cycles. Soon after, however, it blocked up again. I tried the air compressor again, allowing both the back hose and front hose to drain, but with no success.
Any other suggestions?
I've never worked on a Bosch washer, but other techs here may have and can assist you.
If no one else replies to this thread, I can refund your $5 Membership fee, and you can still have free Lifetime Membership.
Whats the model# of your washer, I can check for some tech. literature at least to assist you that way.
