RandallBosch
- B22CS30SN
- Bosch
- 6-10 years
Hello Crew,
I searched the forum, but could not find the Service Manual for my Bosch B22CS30SN Side-by-Side Refer.
My issue:
Unit not making cold on either side.
No error codes when pressing "+" and "-“.
All Fans running.
No 'ice' build up.
Compressor seems to run after initial start-up, but then stops.
The evaporator heater show 63 ohms.
The heater 'element' at base of, and below evaporator shows 370 ohms (reads 0.370 with MM set to '2K') resistance.
The evaporator thermal fuse shows 0 resistance. Is that the same as 'Good' continuity?
The evaporator thermistor reads 7.0K at room temp and 14.8K ohms resistance at 32'F.
Is it possible to 'jump' any of these components to make the fridg run (to check that the control boards are functioning)?
Any help or a link the the Service Manual would be greatly appreciated.
Thx!
My issue:
All Fans running.
No 'ice' build up.
Thx!
