Bosch Dishwasher SHP65T55UC leak
elpeger
west windsor, nj
SHP65T55UC
Bosch
Our 6-yo Bosch SHP65T55UC started leaking. Each run generates about 1 cup of water. We see where the water is coming from -- see picture, but we have no idea what to do to fix it.
We have cleaned out the filter, and that didn't help. It drips when the dishwasher is draining the water out.
Any ideas?
Much thanks
DK
Robert4
Houston, TX
Your model number should have two more digits after SHP65T55UC. The thing with the three holes is the diverter motor.
I've got a suspicion of where the leak is coming from. Take some close up pictures of the rubber gasket in the tub where the back wall means the bottom of the tub, as well as the back corners.
Have you taken the dishwasher out? Look for any wet spots on the back or rust on the screw(s) back there.
elpeger
west windsor, nj
@Robert4
Thanks for the reply. The full model name is Bosch SHP65T55UC/02 (I thought the last 2 characters were for color/finish).
We've taken the dishwasher out. There is no rust or wet spots anywhere in the back. The closeups of the rubber gasket on the lower back of dishwasher are in the attached video (pictures were bad due to reflection from the stainless)
Robert4
Houston, TX
Is that a tear/bubble in the gasket or is it a reflection?
Also, check to see if the diverter motor gasket (key #0408) is damaged:
elpeger
west windsor, nj
I manually checked the back wall gasket and it is all very even, with no tears. Also, wouldn't a tear in the gasket cause dripping anytime there is water in the tub? The dripping happens very clearly only when the water is flowing out of the tub (i.e. being removed/sucked), not when it is flowing in. What issue would be consistent with that?
Thank again.
Robert4
Houston, TX
Yeah, I would think so. You would see wet insulation and/or rusted screws if that were the case. Like this: https://www.applianceblog.com/mainf...5uc-07-bosch-dishwasher-help-with-leak.76182/
@Jake, What do you think?
When water is flowing out of the tub only its leaking? Then I'd check the drain hose from the drain pump and the drain pump itself for leaks.
elpeger
west windsor, nj
The update is that I recorded a detailed video of the leak and while (procrastinating on) editing it..... we noticed a burned smell emanating from the kitchen and discovered that the insides of the junction box just melted. So, we've given up on this dishwasher and ordered a replacement. Thank you so much for trying to help.
