- SHPM65W55N
- Bosch
- Less than 1 year
Works well, dishes look clean and dry, but if in a clean dish touch by wet fingers it feels a little bit soapy if lick it, it has a bitter taste, or aftertaste, which hard to eliminate from the mouth.
This is not dependent on the washing cycle. A few rinse cycles after a washing slightly improve the situation, but cannot eliminate that soap and bitter taste, even an additional full washing cycle without detergent will not work.
Only washing with a dish's detergent under warm water by hands can help.
After any washing cycles, if cancel drying, the drops of the water on dishes looks turbid, and become better after each of following rinse cycle
Also after an additional rinse cycle on the bottom of the dishwasher is appears foam.
The water here is soft and actually, 1 teaspoon of detergent is enough to get dishes clean.
I have tried different detergents and their amount, with rinse aid and without - the same result.
Pictures:
1 turbid water.
2 turbid water, and water after additional rinse cycle,
3 foam.
Pictures:
1 turbid water.
3 foam.
