- SHX5AV55UC/22
- Bosch
- 1-5 years
I am currently trying to sort out an E25 error on my Bosch dishwasher. The problem is that is is intermittent. I start the wash cycle, it tries to run the drain pump three times, then throws the error code. I clear it and try to run it again, and it runs fine, or it doesn't, there isn't a pattern. Sometimes it gets deeper into the wash cycle before throwing the code.
I've had the filter out. I've pulled the drain cover off (and ensured it was securely replaced). I wound up even taking the entire unit out, pulling the drain motor, checking the "interior" drain hose, and flushing the exterior drain hose (to the disposal). I don't feel it's the pump, because it WILL run properly. I have re-seated the drain cover a few times and ensured it's secure. I have no idea what to do next, but this issue is getting really annoying.
It's a couple of years old and has run fine until a few weeks ago when it started throwing the error. Any advice? Thanks!
