FIXED Bosch Dishwasher SHX68TL5UC/07 Watertap error
satcomtim
Georgia
SHX68TL5UC/07
Bosch
Have a bosch SHX68TL5UC/07 that is failing to run with a "watertap" error on the display. I can not seem to find how to display anything else (i.e. EXX).
Rinse cycle starts with pump water out of drain hose for ~10 seconds then nothing else comes out
I have:
1. Cleaned waste filter and pulled pump cover to ensure nothing is stopping impeller. Same results
2. Removed drain line from garbage disposal, it was clean and no obstructions and ran it to bucket. Same results
3. Removed water supply line and ran water through it (no obstructions) and removed the supply filter on the dishwasher inlet. Same Results
4. Pulled off water supply valve? the supply line connects into and cleaned it and reinstalled. Same Results
I can not find where/how to get the E code(s), just the "watertap" red message.
Any thoughts or ideas?
Tim
Excellent Tim, glad to hear the new water inlet valve fixed it.(y)
Here's the water inlet valve for your model, in case others need it too:
628334 Valve Access
