Bosch HBL3350UC/09 oven says it’s preheated 75 degrees or more before it is
Bepding
AL, USA
HBL3350UC/09
Bosch
Hi all-
Back again. My Bosch wall oven is acting strangely, twice in the past couple months it’s said it preheated to set temp (400*) and in reality it never went past 150* measuring by a thermometer I keep inside. I reset the breaker and it started working again. Like I said that’s happened twice in 6 months, but I’m also noticing that everytime I turn it on it will say it’s preheated (beep noise) anywhere from 75-150 degrees lower than it’s set for, but does eventually continue to climb to the set point over a very long time.
I replaced the thermostat on the oven and main PCB about 3 years ago. Not sure where to start troubleshooting this issue if you guys could help point me in a direction. Thanks!
Brian
