FIXED Bosch HDI7281U/07 SIR glass cooktop replacement
APJJR
Charlottesville, VA
HDI7281U/07
Bosch
I have a Bosch HDI7282U dual fuel range. The glass top got broken during the remodel of my kitchen. I have the replacement glass in hand. I am looking for some guidelines on removing the old glass. What to start taking apart 1st. Bosch supplies no such materials. I suppose I could just start with the burners but thought I'd ask first.
Thanks for any help - Alex
APJJR
Charlottesville, VA
SOLUTION: In case anyone else wants to know, just remove the burners and 1 screw in the center of the back. There are 3 posts to which spring clips on underside of the glass attach. Lift the back of the glass off the posts and pull out from under the control panel in the front. Install the new glass in the reverse order. Watch that the excess rubbery adhesive used to attach the spring clips to the bottom of the glass does not get in the way of the new glass seating properly. Just trim off the excess that squirted out from the base of the clip brackets.
Thanks Alex for letting everyone know. (y)
