Bosch Microwave, runs for two seconds and cuts out
Prak
British Columbia
HMB5050/01
Bosch
Hey everyone, turn the microwave on, runs for two seconds and then cuts out. Power is still on, just cuts out. This happened after someone accidently ran it for 20 minutes with nothing in it, instead of using the timer function for 20 minutes. Less than a year ago the magnetron was replaced because it had the classic bosch microwave problem where it would run for 10 seconds and cut out. Any suggestions?
