Bosch MW door sticks
rwsinky
Lexington, KY
HMB8050
Bosch
Our microwave oven door sticks or hangs. To look at it it is crooked or cocked in the opening. Is there any adjustment to these doors? I could not see any. Have no reason why this should be this way as it has not been hit or abused in anyway. Looks like it might have just sagged under it's own weight. Maybe just a poor design.
Russ
I found HMB8050-01 & HMB8050-02
Not really, remove power, remove outer shell and see if the hinges have screws that can be loosened to adjust the door a little and then re-tightened.
