Bosch Refrigerator Leaking - Evolution 500 Series B20CS50SNS
thiggins002
New Jersey
B20CS50SNS
Bosch
Hello - Our Bosch side by side refrigerator (B20CS50SNS) started recently leaking underneath towards the very front. It's not a constant leak - it only seems to leak a few times a day. I have placed a large tray underneath that catches the water and small plate on the very end that gets filled with water too. Refer to attached pictures.
We have turned off the water connection and turned off the ice machine, but it continues to leak. It doesn't appear to be coming from the water line.
We do NOT have any ice build up or anything leaking in the freezer or refrigerator. It's purely coming from under the refrigerator - seems to be on the freezer side.
This refrigerator is about 13 years old.
Any assistance would be appreciated and a small reward too (if that's allowed). Thanks in advance.
I'd first check the defrost drain hose to make sure its not cracked or broken, it mounts above the defrost drain pan.
#0609 is the defrost drain hose
#0608 is the defrost drain pan
You'll need to pull the refrigerator out from the wall, then remove the lower rear access panel and get a flashlight and you should see the defrost drain hose coming down from the freezer section compartment.
Open the freezer door and see if there is any ice on the floor in the freezer
thiggins002
New Jersey
There is a little ice that is "stuck" to the floor the freezer (inside the unit), but I wouldn't say it's a significant amount. The ice is definitely not melting and running onto the floor from the freezer. What would the ice on the floor of the freezer signify?
Sounds like the drain hole in the defrost pan is blocked. Everytime the defrost cycle melts the frost on the coils the water has no place to go except on to the floor of the freezer and then out the door.
ErikD
Washington DC
The issue is with the water line that feeds the water dispenser in the Freezer door. Most likely cracked. I'm having the same issue with mine and could use some advice on how to disassemble the freezer door to get access to the water line.
What's your model number? I have very little information on Bosch machines
ErikD
Washington DC
B20CS50SNS, the same as in this thread. Seems the water line that feeds the water dispenser has developed pin hole leaks, right before entering the door at the bottom, the white hose in the photo above. On other makes this water line can be easily replaced by disconnecting and pulling out the line and fishing in a new.
However on this model, I read online, that it is foamed in place. The whole door needs to be replaced for this leak. Before I do that I was wondering if a panel (front or inside) can be removed to gain access in an attempt to change this hose.
Unfortunately there's not on that model.
thiggins002
New Jersey
Rick - You were exactly right last time that the drain hole was blocked. We took apart some panels and cleared/melted the drain hole. We were sitting pretty for about 7 months, but it just started leaking again. We cleared the drain hole a few days ago and thought we would be good for a while, but it just started leaking again.
What would cause the drain hole to keep "freezing over"? Is it easy fix for an appliance technician or time to get a new refrigerator.
As a reminder, it's a Bosch side by side refrigerator (B20CS50SNS) that's about 13 years old.
Blocked drain holes can be a challenge. If a drop of water freezes at the entrance to the drain hole ice will build from there. The drain line must be clean. Hot soapy water and I use a evap cooler brush. The defrost water has a way of getting under the tray, behind the tray and in the tray. The water freezes and when it does it expands. This causes the evap tray to bend until it's enough to keep all the water from draining. Any water from the defrost cycle that doesn't drain turns to ice. The ice will continue to build up with each defrost cycle until you're back to where you started.
