Bosch SHP65T55UC/02 Control Panel Wiring
Dhyhdyjbf
United States
SHP65T55UC/02
Bosch
I just replaced my soap dispenser on the Bosch SHP65T55UC/02. I took some pictures while taking it apart, but I guess I should have taken more. Looks like I have an extra wire. The connector has a blue line on it. The control panel lights up and I can choose settings. I was considering closing it up to see if it runs, but figured it would be good to ask just in case.
I’ve attached a picture showing the unattached wiring connector.
Thanks for your time and assistance.
Have a great day,
Sam
Don't know if you have this figured out Sam, but a few of us have had issues with the rinse aid/soap dispenser and we noticed that a wire was missing from the bottom right hand corner. I came across your question answering someone else's question.
Check your dispenser and you might be missing that wire. Ours don't have the blue stripe on it but you might want to check that. It worked for us. I have the SHP75PT55uc/07 model but I'm assuming they're pretty close to one another. Good luck!
Thanks for your reply. I should have followed up on this. It seems to be wired correctly in the above photos. Everything has been working fine.
