Bosch SHX4AP05UC/06 does not completely drain
MIKEINMN
MN
SHX4AP05UC/06
Bosch
Water not completely draining. Used a turkey baster to suck out the water to get to this point. Filter rinsed out and is clear. I looked at other Bosch videos of similar problem and they removed a white cover to the impeller and a check valve that has a tenedency to get clogged up. From this picture is this white piece a similar cover? Other models had a T-15 screw to remove. I do not see one here. Pulling on it seemed like it may be difficult to remove and break.
Am I headed in the right direction? What else should I try?
Hi Mike,
Looks like you have the newer design Bosch model and the check valve is underneath the machine where the drain hose connects to the sump.
When you click the check valve part link below, you will see a video of how to remove to see if it's partially clogged up and how to replace it.
Here's the check valve for your model:
00611320 Check Valve
