Hildebrau
- SHX68E15UC
- Bosch
- More than 10 years
Good morning. I hit my first E15 error code yesterday on my Bosch SHX68E15UC dish washer from 2011.
This was 10ish months after replacing the circulating pump based on an E24 thread and that E24 disappeared.
I hit the forums and youtubes late last night and ripped open the dishwasher. I sponged out the water I found around the styrofoam float and ran a (very LONG) 30-minute cycle and watched it closely. Well, I guess I got bored near the end and looked at my phone instead. That's when I missed it leaking again. The leak did NOT come from the door seals, or the drain hose connection. I do see a thin water ring between the stainless main tub (sorry if that's the wrong term) and the whole plastic parts that start below the tub... so I imagine it's leaking there; but I never saw it "running" out. I also see water pooled directly under the circulating pump that I replaced late last year. But there's no telling if the water came from a connection on that or if it just came from above and happened to pool there.
I took a video and a few pictures from last night after my 30 minute test cycle. Can anyone tell guide me on next steps? Click the album link to see the photos.
I'm thinking I will dump a gallon of water in to the washer and watch below to see if it just leaks w/o running. If it's the gasket between the tub and whatever you call the thing directly under it, then I guess I'm in for a LONG repair job based on some videos I saw last night. TMI: I've had washing machine spider arm fail two weeks ago and fridge water filter leak last week. I'm tired of being appliance repair guy.. I need a break!
If you can suggest parts and any videos that closely represent my model, that will help me big time. I never could figure out how to remove the plastic bottom basin when I did the circulating pump replacement last year. Looks like I'll have to figure that one out this time around. No getting around it!
Thank you so much!
-Hildebrau
Thank you so much!
-Hildebrau
