applegate123
- SHX6AP02UC/06
- Bosch
- 6-10 years
Dishwasher just started doing this over the past week. Start is pressed, then you close the door and it appears to start. But shortly after, if I check, the washer says CLEAN, but it did not start the wash, drop the soap or anything. But the CLEAN light turns on. I am guessing that the clean sensor is not resetting correctly - so when I start it, it detects the sensor as clean and just turn on the light and stops. The CLEAN sensor resets when the door is opened. I was wondering where that sensor is located or it if is can be separately replaced? Or if there is some other suspected issue. Or is this all part of the control board?
