joeltk
- HBL8451UC
- Bosch
- 6-10 years
I have a wall oven that was not getting to temp. Issue was not with the elements, as the clean function worked. I first attempted the clean the probe, that did not work. I called a service repairman who advised the control board and probe should be replaced. His quote was $500+ in labor, so I endeavored to attempt a fix myself.
I replaced the control board and the probe. I ensured the control board connections were correctly made (took pictures of the old board before installing the new board, etc.). When I powered it on, the digital display did not turn on. The oven light will work and the only buttons that make a sound when pressed are the oven light and clock.
Do I need to replace the display board as well? Could this be indicative of a poorly installed board? Any suggestions?
Thank you in advance.
