Bosch Washer Error Code 03
Mr. G
california
BOSCH WFK2401UC Washing Machine does not drain water and CODE 03 and Rinse/Spin Door Locked lights flash. Once I drain water unit machine will high speed spin. One more thing when I opened the door the washer free spun very easy.
Thanks in Advance
TechnicianBrian
Portland, OR
The error code you are giving is for a door lock error, but that doesn't explain the unit not draining. Try putting the unit into diagnostics and report back what the error code displayed gives. Then we can have a better idea as to what the control board is thinking. Once in diagnostics, the last error should display, then return the selector to off to exit the mode.
Rotate selector switch to​
[FONT=Arial,Arial][FONT=Arial,Arial]Off [/FONT][/FONT]position. Press & hold [FONT=Arial,Arial][FONT=Arial,Arial]Menu[/FONT][/FONT]& [FONT=Arial,Arial][FONT=Arial,Arial]Select [/FONT][/FONT]buttons (located under display), then rotate selector switch [FONT=Arial,Arial][FONT=Arial,Arial]ccw [/FONT][/FONT]to [FONT=Arial,Arial][FONT=Arial,Arial]Permanent Press Cold [/FONT][/FONT]until display comes on.
