- SHX68TL5UC
- Bosch
- 6-10 years
I have a Bosch SHX68TL5UC that stops running after two or three minutes starting a cycle with "watertap" on the display, and it then keeps beeping. There is no error code listed on the panel.
I have done the following:
1. Checked and cleaned filter.
2. Removed drain line and checked to ensure it is clear.
3. Removed water supply from the sink and checked that water pressure is fine.
4. Checked water supply hose to the dishwasher to ensure it is clear.
5. Cleaned filter connecting to the water supply filter.
The hoses are not bent. The unit appears to be draining properly.
Are there any ideas to check?
