Bottom freezer drawer does not close
vdolnik
Palo Alto
Monogram
The bottom freezer drawer did not close completely with a small opening (about 1/8 inch) on the left side. I replaced the worn rubber gasket seal it did not helped. I checked the rails, they worked fine and there was not any obstacle there. I took the front of the drawer off and checked how deep the rails could go. It comfortably switched light off and there was not more than about 1/8 inch between the back wall and the rails. I could not see anything that caused the problem. Even speculated about bended drawer but the drawer perfectly closed in past and nothing serious happened in between, so I must be simply overlooking something.
