Breaker trips on 2001 Whirpool GD5LHGXKQ00
well, I tested it ... not easy. top part of the element is rubber (probably part that does not get hot)... Had to pull it out a little to get to it on the right side. measured .222 to .240 on the highest ohm meter setting i have which is 2M.
Nuisance Tripping of GFCI’s and ARC Faults – Progress or Politics?
Appliances tripping the ground fault on GCFI outlets is a common issue that blurs the lines between appliance and electrical issues. This dilemma can create a stalemate, with both appliance technicians and electricians potentially being correct in their assessments, signaling an conflict between technology, safety, and regulation.
Modern appliances incorporate technologies that may inadvertently cause GFCIs to nuisance trip, a problem expected to worsen with more stringent regulations introduced by the 2023 National Electric Code (NEC).
While these devices aim to ensure safety, they can sometimes lead to inconvenience or more significant issues like spoiled food due to unnecessary shutdowns of appliances. However, various strategies can help us navigate these complex situations, ensuring the right balance between safety, regulation, and appliance functionality.From United Appliance Servicers Association: FYI I would change it to a regular outlet.
so the test reads as .222 ohms up to about .240 ohms.
There should be infinite resistance (NO continuity, none) between either power lead and the heater body. ANY resistance between them is a short.
If your readings are correct the defrost heater is defective IMO.
Big Buck, you need to come to Monroe County, Indiana. There isnt a line in my house that doesn't have a GFCI on it. Its required by code. Welcome to Indiana!
