C970-430031 Kenmore Pro Dual Fuel Range oven temperature setting
GGRay
Vancouver, BC
C970-430031
Purchased new 2012 - problem is oven temperature setting. Regardless of what oven mode is selected the temperature readout jumps around, e.g., set it for 350, and it might read 340, 290, 310, etc., and then go blank. The over starts to heat but I have no idea where it's going to end up. A tech came out and found no obvious errors such as loose wires, etc. I thought it might be the oven control board, but am having problems finding in Sears parts websites as my model number doesn't register as a Kenmore number. Manufactured by Kelvinator, maybe?
GGRay said:
am having problems finding in Sears parts websites as my [model] number doesn't register as a Kenmore number.
No, because you have a Canadian Kenmore range which is nothing to do with Sears in the USA. Your model was made by Frigidaire. If you contact Frigidaire Canada they should be able to look up any parts for it you need.
