- CHS900P2M1S1
- GE
- 1-5 years
My 3 year old cafe´ Induction range top stopped working correctly. (The oven is fine) Using the usual cookware it will heat for about 10 seconds then just shut down. Tried the Hestan "precision" cookware too, no joy. Even pulled the battery from the pan in case that was causing an issue. First acted up while boiling a pot of water fan started running more than usual then shut down. Was able to finish cooking using different burner. But now, nada. Tried turning the breaker off for 5-10 minutes,no help. The wifi connection is up. In the SmartHq app I can see the controls and it shows the percentage of the knob setting then it just shuts off.
Doing some searching It seems like the Induction Control unit may need replacing. WB27X30357. A bit pricy but I did find one. Does anyone have a service manual? or disassembly guide?
