Can't access diagnostic mode...
CKrypto
Florida
WRF560SEYM00
So, I am trying to troubleshoot a frost problem in my freezer by accessing the diagnostic mode to determine if the issue lies in the defrost element or in the thermistor. The problem is that no matter how many different ways I try, the unit will not go into the diagnostic mode as described in the service notes. I was just wondering if I am doing it incorrectly, or if there somethings that I have to do before holding down the buttons on the front panel. Also, if I am doing it correctly and it is still not working, would that be indicative of a malfunctioning control board? I had recently replaced the control board after a power surge made it so the unit wouldn't even turn on. Just looking for some opinions before I go out and start buying replacement parts. Pic below is from the service notes for reference. Thanks!!
Is this the control board you replaced: WPW10336511 Electronic Control Board
If you are following the tech data sheet steps to get it into the diagnotics and its not going into it then what happens when you try? Are the buttons responding at all when you press them?
CKrypto
Florida
Yes, that is the part that I replaced about 6 months ago.
If you are following the tech data sheet steps to get it into the diagnostics and its not going into it then what happens when you try?
I hold the buttons for 3+ seconds and nothing at all happens, then there is a single beep when I release the buttons and then nothing. I've tried combinations of buttons including holding SW3 and SW1 and still nothing happens.
All of the buttons appear to function correctly when pushed for their intended purpose.
When you order parts from AppliancePartsPros or RepairClinic, you have 365 days warranty and 365 days to return any part for a full refund, less shipping, for any reason period! Even if you installed it!
I'd return it for another one under warranty.
