E61--->Heater Relay Failure--->Heater relay stuck open or closed; Wiring defective.
Check for short circuit across heater relay(s) (RL5, RL6, RL7) or L1 applied to heater relay output(s) (J5-2, J7-1, J7-3) with cycle stopped. Check for open circuit between L1 and heater relay connection(s) (J5-1, J5-3, J7-2). If no wiring problems are found, replace Electronic Control Board and retest.
Here's the Electronic Control Board for your model:
809160802 Control Assembly
Here's the instructions, Just read where it says Control Assembly - Figure 4-17:
(click to enlarge)
