CAW9244DW1 Crosley Washer Drain Pump Always Runs
mightyorion
SW Louisiana
CAW9244DW1
Crosley
Hello All,
New to the forum and trying to help a friend out that has hit hard times and is not able to purchase a new washer. The Crosley washer is approximately two years old, no matter what cycle is selected the drain pump constantly runs (for as long as you'd allow it to) when the start button is pressed until the cycle is cancelled. Went into diagnostic mode and the unit will fill, spin, agitate and of course drain manually. Unplugged the unit for one hour, set the dial to "Regular", plugged it back in and still the same issue. Next selected "Drain and Spin" cycle and when start is pressed the original issue remains. Verified great water pressure to the unit supply ports and ensured the drain hose is high enough to prevent siphoning. Any and all assistance is appreciated, Thanks!
**Edit - Also, the machine will not complete or initiate calibration in diagnostic mode. Also, when a normal cycle is selected and the start button is pressed the "Fill" light only quickly flashes before extinguishing.
Without a model number, we're dead in the water. Read it from the tag on the machine. Click here: http://www.repairclinic.com/ follow the link “What is a model number, and where do I find it?”
