CCE3401 Jenn-Air Radiant Cooktop element stays on HIGH
dbauman9
Michigan
CCE3401
Jenn-Air
Jenn-Air Radiant Cooktop (model CCE3401) right back element stays on HIGH no matter what the setting. Will not shut off unless I turn the knob to off.
Any suggestions?
The problem is the burner switch.
Here's the burner switch for your model you can order: W11088181
dbauman9
Michigan
My Jenn-Air cook top (Model CCE3401B) has a smooth surface with the coils below black glass and the on/off knobs front/center above the glass surface. Is this the same part that's needed for this model to repair this problem?
Yes, that is the correct burner switch for your model.
#2 is the burner switch
The 2nd #2 is for the DUAL burner, but you said the problem is the right rear burner, not the DUAL burner.:)
