FIXED CFEF355FSC Not getting hot
SeanKaven
Hanmer
CFEF355FSC
Frigidaire
Hi there I have a stove model Cfef355fsc all 4 elemts on stove top get warm but not hot and don't burn red. Also stove element not getting hot either just warm. What could this be?
Hi Sean,
It sounds like one of your dual breakers is tripped, and that will cause this problem because your only getting 120 volts on one breaker, where you need 240 volts to heat properly.:)
Go to your house breaker box and locate the dual breaker for the range and reset them both by turning both OFF, then ON again.
SeanKaven
Hanmer
Jake I never even thought of that. And it seems you are right. I have the old style fuse pannel and one of the 40a barrel fuses seems to be dead. I'm going to replace them today. Thanks again
Sounds good Sean, let us know how it goes after you replace it.:)
Excellent Sean, glad to hear that's all it was.:)
