CGR3740BDH Oven stopped working: no heat, no gas smell, no errors
loligator
Don't worry about it
CGR3740BDH
Magic Chef
Hello all,
I was using my Magic Chef oven the other day for a little heat in the kitchen in the morning (don't worry, I don't run it for long like this; just long enough to take the chill off). It started warming up, then I noticed the smell of gas and it wasn't getting any hotter so I turned it off. A few minutes later I tried turning it on, it let me set the temperature, but the oven never warmed up. There's no smell of gas. There's also no error codes. It just sits at 350 or whatever temp I set it but nothing happens. No error codes are ever shown, it doesn't shut off, the preheat light stays on, and that's about it.
I've had the igniter go before but this has produced an error code the two times it died previously, the oven would beep, then turn off. I replaced it anyway but unfortunately the problem persists.
I'm not sure where to go from here. Does anyone have any suggestions? The range works fine by the way; it's only the oven that's broken.
Oven ignitor should have continuity, over gas safety valve should have continuity. If these pass ok, we check for power to the oven ignitor....no power and the clock/control is then suspect or the wiring between the ignitor and clock.
Oven-Control-Board-WPW10162787-00846791.jpg Electronic oven control
[video=youtube_share;I7kVsp4GduM]https://youtu.be/I7kVsp4GduM[/video]
[video=youtube_share;-RZtxSvOe-U]https://youtu.be/-RZtxSvOe-U[/video]
