CGS986EEL1DS GE Range - Is it possibly the safety valve?
Gsanbrook
Tyler
CGS986EEL1DS
I have a GE profile gas range. Electrician wired 220v to the 110v outlet. Long story. Wife turned on broiler and it zapped and didn’t light. That’s when we figured out the 220v problem. Igniter not glow and oven light no light. Replaced control board and igniter. Oven light works now but no power to igniter. Visually, nothing burnt. It seems the feed goes to the igniter and then down under the range, where I assume is the safety valve. If the safety valve fried by the 220 could it stop the igniter from at least glowing?
Definitely. It is easily tested:
The valve for your model is a 'dual' valve and works like two separate values as shown. One side for bake, the other side broil. Each side should measure similarly.
These links are pertinent to your message. They were supplied by this message author.
LINK > CGS986EEL1DS Dual Valve and Pressure Regulator WB21X33225 (good photo ✔️, no stock ❌)
LINK > CGS986EEL1DS Oven Dual Valve Asm WB21X33225 (no photo ❌, in stock ✔️)
