CGS990SET8SS GE Range Pops circuit breaker in panel
Flecker
Round Rock, TX
CGS990SET8SS
The lower oven when using convection roast pops circuit breaker after heating to desired temp while food is in the oven. I reset the breaker and it works until the next time it is used..
When did the lower oven start doing this tripping the breaker? Is anything else pulled into that outlet? Have you tried a different outlet that's on a different breaker?
Use a extension cord to reach another outlet. Usually when the problem is not the range if it doesn't trip the breaker right away when you first turn on convection roast.
Flecker
Round Rock, TX
Thank you for your help. I plugged it into a different plug no issues. Plugged it into the original plug and found out the circuit for the oven also runs my office. My son was on his computer and when I turned the oven on it shut the room down.
Yuppers, that will do it.:)
Ok, you will need to have a electrician come out to see what's going on.
You probably just need a new breaker.
Ok, I don't know then, sorry. That's a first for me too!
But it seems to me its in your house electrical because you said this: I plugged it into a different plug no issues.
