Changed drain pump, still get error code E25 Model SHE3AR75UC/14 purchased 2014
imaginaxion
SHE3AR75UC/14
Bosch
I was getting an E24 error signifying a blockage in the drain system. I disconnected all hoses right to the drain pump and checked they were clear by pushing a piece of electrical cable through it. No debris was evident and no blockage was present.
I then proceeded to remove the drain pump, and run it outside the housing. it appeared to run OK. No dirt or debris anywhere.
I then removed the check valve which looked ok, and reinstalled the pump.
Error went from E24 to E25. Knowing that the drain line was clear ( I even removed it from the connection under the sink and put it the end in a bucket)
I ordered an new pump. After installing the new drain pump, I still get an error E25 and the dishwasher won't drain.
Here's our main thread on the E24 and E25 error codes:
Jeff knows a lot about Bosch, much more than me, but unfortunately hes taking time off for personal reasons, so read that thread over carefully and see if anything in it will fix yours.
